Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
iPhone 5 No Service after replacing camera.
Hi, recently I changed the rear camera of the iPhone 5. The camera was not working so thats why. But after replacement the phone says No Service, but the phone was receiving signal fine before replacement. I have no idea what caused it. I also tried to replace the entire bottom part because I thought it would be that wire which connect to the logic board is damaged but that did not worked as well.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Under the iPhone’s battery plate, there is a silver connector which has to be unscrewed prior to disassembling the iPhone. If this connector has not been replaced properly, the iPhone will fail to connect to a mobile network. Check the post below to deal with the problem:
How to Fix iPhone No Service after Screen Replacement
Was dit antwoord nuttig?
Voeg je antwoord toe
Mirza Zaheer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 93
