Ga door naar hoofdinhoud
Repair guides for Windows cell phones manufactured by HTC.
37 Vragen Bekijk alle
Windows was unable to complete the format
Hello, friends! My HTC phone SD memory card recently just asks to format when it was used on my Windows 8 computer. However, when I click Yes to format SD card with my computer phone SMS, games, files and photos, windows just says windows was unable to complete to format? Honestly, I have used Google to search for the related windows unable to complete the format error problems and also am wondering to select a formatting program? Do you have any recommendation? Is such software helpful for my case? Thanks for any suggestion here!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Hi, you can just format your SD card by Command Prompt :
1. Insert the USB Flash drive into your laptop or computer; wait until it will be detected.
2: Open Command Prompt by following this flow: Start →Accessories →Command Prompt or Start → Run → type “cmd” → Enter
3: Assuming your USB flash drive is assigned the letter “F”: type the following command in the Command Prompt with the following:
format F: /fs:FAT32
If you would like to convert the file system into NTFS, FAT, exFAT, just change FAT32 to the target file system.
Step 4: To continue or stop the formatting process, press Y (for Yes) or N (for No).
I think it’s no need to use the program, it’s not safe sometimes, you can just use the command on pc to complete your format.
Was dit antwoord nuttig?
Voeg je antwoord toe
Reo0Yu0 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 138
