Ga door naar hoofdinhoud
Third generation of iPad, featuring 4G capabilities, released on March 16, 2012. Model number A1430. Repairs require heat and careful prying.
106 Vragen Bekijk alle
iTunes error -1. Maybe Hardware defect?
Hi,
As anyone had seen the error -1 (unknow error)? Any suggestion for solution?
I had read, that is an hardware problem on Nand Flash, maybe right?
The iPad 3 (A1430) wont turn on after an update.
When i disassemble it, i had checked that the Main Board Flex Interconnector is broken.
I had resolder the terminals and buyed an new flex, but i have my doubts that this is the problem. I'm Wainting the Flex Arrive.
Sorry if some English errors :D
Best Regards
Paulo Silva
Is dit een goede vraag?
Score 1
2 opmerkingen:
-1 is usually the baseband
door
Hi,
I will try to Reflow it and check if it works...
Many Thanks
door
Voeg een opmerking toe
1 Antwoord
was this resolved?? as im having the same issue
Was dit antwoord nuttig?
Voeg je antwoord toe
Paulo Silva zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 362
