Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Vragen Bekijk alle
iPhone 6 disabled, emergency call one, TOUCH id no go
Took my phone screen cracked, got moisture in it, screen began to glitch and got to the point of really bad distortion, it began to malfunction and make calls out, bring up random applications with out command. Phone became disabled. Took it to Batteries plus and paid 122, guy said the battery was swollen and strip is red verses white, he didn't want to take out the battery until we knew for certain that there was no internal issues.
Touch ID isn't working after the screen replacement. Now that screen is fixed iPhone is asking to be connected to iTunes with iPhone disabled screen, when I swipe it only gives me emergency dial pad, so I cant enter passcode for iTunes to allow sync! How do I fix this?!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Do you have a computer that has iTunes on it that you have already synced with in the past? If so then you can use that to restore through iTunes without needing to sync it again.
Otherwise follow the instructions here : https://www.theiphonewiki.com/wiki/DFU_M...
This will put your phone into DFU mode which will allow you to restore the device through iTunes without syncing it. Once you have restore the device you should be able to set it back up.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
OP: DO UPDATE FIRST, it might remove the disabled without needing to restore the phone which basically wipes anything. Use restore as last resort.
door
Thank you! I was able to save it and fix the screen. :)
door
home buttun not working,touch id not working,how to unlock my disabled iphone with emergency
please help me how to unlock my phone with emergency number
sir,when i connected to lap the usb also not connecting,help me sir
Voeg je antwoord toe
Chandelle zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 972
