Ga door naar hoofdinhoud
The Motorola Xoom is an Android-based tablet computer by Motorola, introduced at CES 2011 on January 5, 2011. It is the first tablet to run Android 3.0 Honeycomb.
43 Vragen Bekijk alle
Why won't my tablet take a charge.
I changed the battery with a brand new one cause the old one wasn't holding a charge any more. Now I can't get the new battery to charge at all. I checked the charging port to see if it was damaged but it looks good. Do I have to rest the table back to how it was when I got it ? Don't know what else to do.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
please check the another outlet . If all else fails just walk into a Verizon store and tell them what's going on. They are usually pretty helpful in getting a replacement device for you
Was dit antwoord nuttig?
if your tablet has a micro usb charging port , they tend to get a bit touchy after a while. you might try and place the tablet on a flat surface and put something under the plug to apply a little pressure on the connector . trying it with the tablet face up or face down. those jacks seem to all get touchy after a while.
Voeg je antwoord toe
Christine zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 733
