Ga door naar hoofdinhoud
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
Trackpad sometimes not tracking
I have a MacBook that I bought used and I was unhappy to find out that the trackpad doesn't work 100%. It often stops tracking when you move our finger across the center of the trackpad. It will often not be able to pick up the scroll gesture properly. Very annoying, I love macs excatly for their quality track pads. Any suggestions for how to fix the issue?
If I have to replace the hardware, I'd like to replace the part myself. I don't see a part listed for 15" trackpad, can you just use the trackpad for the 13"?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Well ... Yes & No here ;-{
The problem here is Apple glued the battery into the case and the battery covers the trackpad (I know who would do such a dumb thing!) Here's the IFIXIT guide you'll need to follow: Battery and Trackpad. Disassembling MacBook Pro 15" Retina 2012-2015
Taking the battery out will damage it and its just not wise to try to reuse the battery. So you'll need a new battery in addition of the trackpad $50 US {Apple P/N 821-1610} (aprox. $180 US for both). The other option here is to replace the uppercase which is the easier to do, but much more expensive: MacBook Pro 15" Retina (Mid 2012/Early 2013) Upper Case Assembly.
Replace an upper case and keyboard compatible with the Mid 2012 to Early 2013 Retina 14" MacBook Pro laptop. Afbeelding
Product
MacBook Pro 15" Retina (Mid 2012-Early 2013) Upper Case Assembly
$89.99
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
kellen sunderland zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 160
