I got this off the county library site, hope it helps.
3.0L SOHC & 3.5L Engines
Remove or disconnect the following:
Negative battery cable
Air intake hose
Alternator drive belt
On California models, remove the rear bank converter assembly.
Remove the engine roll stopper stay bracket assembly.
On the 3.0L SOHC engine, disconnect the EGR temperature sensor wire and remove the EGR pipe assembly.
On the 3.0L SOHC engine, remove the intake plenum stay bracket assembly.
Alternator wiring harness connectors
Alternator upper and lower mounting bolts
From beneath the vehicle, remove the alternator.
To install:
Position the alternator on the lower mounting fixture. Install and tighten the mounting bolt and nut to 14–18 ft. lbs. (20–25 Nm).
Install or connect the following:
On the 3.0L SOHC engine, install the intake plenum stay bracket and tighten the mounting bolt to 13 ft. lbs. (18 Nm).
On the 3.0L SOHC engine, install the EGR pipe and tighten the fitting connections to 43 ft. lbs. (60 Nm).
On the 3.0L SOHC engine, connect the EGR temperature sensor wire.
Engine roll stopper stay and tighten the mounting bolt to 35 ft. lbs. (45 Nm) and the nut to 36–43 ft. lbs. (50–60 Nm).
Rear converter assembly, if removed
Drive belt and adjust the tensioner until the proper belt tension is achieved
Air intake hose
Negative battery cable and check the charging system for proper operation
Copyright ©2016 by Chilton, an imprint of Cengage Learning
This question was migrated from http://meta.ifixit.com/Answers.
door iRobot
