Ga door naar hoofdinhoud
Repair guides and support for the fourth generation of Ford Mustang, including the Mustang GT and Mustang Cobra.
58 Vragen Bekijk alle
overdrive is not working the way it should
when I am driving between 40 and 50mph it works fine but when over 50mph when you give the car gas it keeps kicking out of overdrive until the computer goes into default mod then it works fine
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
It might pay to get a code reader on it & let us know what it tells you. Sounds like the transmission control computer is giving problems. Open it up & have a look for the obvious capacitor leakage problem with this one. These computers have a history of SMD chip resistors going open circuit, which is impossible to spot, but easy to measure with a multimeter. I've personally repaired hundreds of similar systems over the years.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Dale Plantz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 109
