Ga door naar hoofdinhoud
Sony Xperia Z3 Compact released in Sep. 2014.
20 Vragen Bekijk alle
wifi problem after lcd and back cover replacement
hello, i'm Dan, i have a problem with my z3 compact's wifi. I replaced the lcd and the back cover, and the wifi don't work good... The signal at 2,4GHz is so bad and at 0 mb in download, with the 5GHz is a bit better but not enought. I don't know where is the wifi antenna, and if i could touched it or broked it when i moved the motherboard or others.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Check connetor on mainboard and plastic main frame. Wi-Fi antena is in a frame. Check screws and spring connector on mainboard (it goes to frame). Maybe you can broke it or distort it.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
dan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 880
