Ga door naar hoofdinhoud
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
Dualshock 4 controller will not charge.
So my controller is not charging no matter how many cables I try. So I decided to test the battery and see it that was it so I swap the batteries in my two controllers and not neither one will charger so I'm thinking it may be both the battery and charging port on the first controller because when I but the batteries back in the proper controller I get the second to charge. Both are still able to connect to the Ps4 so they're still somewhat good. I also want to add that it is a day one controller having this problems so that may be a factor.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
umm its a little tricky. id assume if you changed the battery and that didnt help, i would reccomend changing out the charge port/led circuit board. and if that doesnt get you fixed then it is the main motherboard in your controller.
Was dit antwoord nuttig?
Voeg je antwoord toe
FIREDEMON zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 963
