Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Vragen Bekijk alle
Unresponsive screen with white bars at the top?
So about a month or two ago, my friend stepped on my phone on accident and cracked it and bent it a bit. At first, the only problem was the cracks, but about a week or two ago, I noticed a white bar are the top of my phone screen glitching and when it does it, my screen is unresponsive. I've tried messing with it to try and forgive out what is wrong, and I think it has to do with it being bent, any advice or fix?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Either the screen is damaged or there is miniature fractures starting to develop on the logic board, and this may effect the touch ic, I would try changing the screen first and see if that resolves your issues, and try get a new housing, to minimise anymore chance of fracturing on the logic board. :-)
Was dit antwoord nuttig?
Score 1
its a common problem in iphone 6 plus. your touch ic is causing that problem. see this video from ipad rehab and try if you can fix it
https://www.youtube.com/watch?v=To6dJYgd...
Score 1
Voeg je antwoord toe
Nelson rivera zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 6,039
