Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Full washing machine cycle salvage?
Co worker put IPhone 5s through full cycle with IPhone on. I've placed it in rice, should get the screwdrivers to open the phone come Tuesday and i'll take it apart and place it in rice for another few days. Placing the new battery I'm buying. Any take on if this is salvageable and if the battery doesn't work, how do I check logic board?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Rice does not do anything for your waterlogged phone except let the water sit longer which causes further oxidation. What you should do instead is take the phone apart. Disconnect the battery and remove all of the components from the logic boards. Remove the covers from the logic boards, as they hold in the water, and run them through a good ultrasonic cleaner for 20 minutes. When finished, submerge the logic boards in 99% iso alcohol for a few minutes to displace the water. Let these dry completely. That should stop the oxidation which is what will cause further damage.
As for the damage that the water is done, it may be too expensive to fix. There are a few companies that can look at the logic boards and make that determination or possibly recover your data.
Good luck and avoid the Rice
Was dit antwoord nuttig?
Voeg je antwoord toe
Joe Eimert zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 70
