Ga door naar hoofdinhoud
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Vragen Bekijk alle
Magsafe Power Light never comes on
I inherited an old MacBook unibody A1342. Tried several MagSafe power adaptors, and I get the same response from all: Nothing. These power adaptors work with other MacBooks, just not this one. I replaced the MagSafe DC-in board, and had no improvement. Took the battery out, thinking this might be the problem. Still nothing. The light on the MagSafe adaptor never goes on, and the computer won't boot (or charge the battery) because it's not getting power.
Any suggestions where to turn next? I hate to invest too much money in this thing, but if it's easily repairable, that would be great.
Thanks! -- Ken
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sadly your logic board is in trouble ;-{
It will cost you around $180 US for a new logic board. Are you up to it?
I would add the following a new SSHD as the original drive was quite small (get a Seagate) and 12 GB of RAM then you should be able to get a few more years of use out of it.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thanks. I had a feeling this was the issue. Logic board is like $280 on iFixit. That's way out of line (used A1324's on eBay are way less than this) so I'll probably pass unless I can find one cheaper than that!
Thanks! -- Ken
door
Voeg je antwoord toe
Ken Getz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 65
