Ga door naar hoofdinhoud
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
My driver's side windows buttons quit working
I've changed my speakers and the radio recently and right after i put everything back together the windows buttons quit workig but the door locks works fine only on the driver's side non of the windows worked but on the other doors the buttons worked fine for a while then all the window buttons on all the doors quit working!! But the door lock still work fine! I checked all the fuses and the connections everything looks fine! please help me
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
It might not be the button, it could be that the actual window motors quit working . You may have to check that.
Was dit antwoord nuttig?
1 Opmerking:
The window motor works fine beside it doesnt wvwn get power when i tested the wires
door
It was just a blown fuse but it was a toyota fuse thats why i couldnt see it.
1 Opmerking:
Where did you find the blown fuse?
door
Voeg je antwoord toe
ameedjaara zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 523
