Double fan on a grand am gt
I have a double fan and only one is working. I belive it is the one that cools the A/C cause it quit working to
Is dit een goede vraag?
If your referring to the 2 fans on the rad one comes on at a certain temp and the other comes on when the temp reaches full operating temp. you can test it to make sure it works by wiring it direct to the battery. It may be a relay if its not working or the sensor may not be working to send the signal to turn it on. Do you know why the air isn't working ? Did the two events happen at the same time ? If you blew the relay for the air then it could also have taken out the fan or they may actually run off the same relay . One last question does the car overheat because of the fan not running or is it running in normal operating temps?
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 91
