Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Asus X54C werd uitgebracht in 2012 en is voorzien van een Intel Pentium, Intel® Core™ i3-processor, Intel® Pentium® dual-core processor en Intel® Celeron® dual-core processor.
Out of date or missing drivers
I ran a scan on my laptop from Universa lDriver Updater it showed 19 out dated or missing drivers
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Het nuttigste antwoord
In general it's best to avoid driver update programs. At best they usually try to sell you something you can get for free, at worst they contain malware. Uninstall it. Then, go to the official Asus computer website, click support, enter the exact model number of your laptop and it should show you a couple of options, one of which will be to see available driver updates for your computer. It's worth mentioning, a lot of technicians will tell that if you're not currently experiencing a driver-related problem then the benefit of updating your drivers is not worth the risk of the update causing a new problem
Was dit antwoord nuttig?
Score 1
You can use the driver updater to get the solution to your problem.
Score 1
Junk files and outdated or missing drivers are those key point which decrease your productivity and system performance. So it would be great for your pc to update your drivers and boost PC speed.
Score 1
1 Opmerking:
Driver updater software helps to improve the system’s performance by keeping all drivers updated with the latest available drivers.
door Deel
Outdated or missing drivers can slow down your system or cause hardware glitches. You can update them using Universal Driver Updater or manually via Device Manager. For a safer, all-in-one approach, try Advanced Driver Updater by Systweak, which automatically scans, downloads, and installs the latest compatible drivers for your PC.
Voeg je antwoord toe
Riz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 28
Altijd: 490
