Ga door naar hoofdinhoud
Model A1288 / 8, 16, or 32 GB capacity
20 Vragen Bekijk alle
I can hear just on one ear
i tried it with some headphones all working but i can hear just on the right ear the other side just dont work=how can i fix it?
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
replace headphone jack
Was dit antwoord nuttig?
on Bose QC25 The right side isn’t working, i did replace the wire, any tip?
Thank you
EASY !!!!
In most cases, it is the speaker that is the problem !!!
Easy to change:
1. 2 screws inside the earcups and the cloth piece (The earcups are "clips" on plce...use your finger all the way around until you hear click....every 2 cm.....)
2. Use a scalpel to open the cover of the speaker (NB!! warm up a bit first...hair dryer works fine!)
3.Unsolder the speaker and solder a new one !!
EVERYTHING OK !!!
Go to Settings - Accessibility - Audio/Visual and check if Balance is right in the middle - I remember once it got messed up by itself for absolutely no reason, but I fixed it this way in seconds
2 opmerkingen:
Why should yoy do this....? when it is no sound in one of the speakers...?
whats the Point...?
door
Try it - you’ll see ;)
door
Voeg je antwoord toe
yuval zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 855
