Ga door naar hoofdinhoud
Apple's 6th revision to the iPod Touch lineup, released in July 2015.
149 Vragen Bekijk alle
Why my iPod not charging
Yesterday i tried to put the USB electrician on my iPod charging port and it pop up " The accessory may not be supported" and now its not charging? what can i do. Now its drained. What can i do please help me.
Is dit een goede vraag?
1 Opmerking:
I think the charging port is clean. When the message pop up "The accessory may not be supported" it stop working. and i turn off the iPod. It still wont charge. and then i click the home and power off button at the same time and it still doesn't work. Do you have more ideas what can i do to my iPod?
door
Voeg een opmerking toe
3 Antwoorden
Did the charger come with the package? If so, i dont know what to do.
Get a proper charger
Was dit antwoord nuttig?
Clean ur charging port with a tooth pick. It works I had to do this on my iPhone!
1 Opmerking:
Its clean. But its not working. Do you have idea what can i do?
door
Does it make the charging sound when plugged in? If not then it's not clogged but jammed with lint! I litterly had to scoop out the lint which I could not see with a tooth pick all the way in the back not the sides.
Voeg je antwoord toe
oscarjosephdamalerio zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 719
