Ga door naar hoofdinhoud
De Dell Latitude E6410 is een 14" laptop uitgebracht door Dell.
Blinking cap locks and won't boot
So being the dummy I am, I spilled some juice onto my laptop. It went though the keyboard and on to the area where my ram is( I know this because there was something sticky in just that part). the power light comes on and so does the fan so I know it's not a power thing. The middle caps lock flashes while the numb and scroll stay solid. I tried replacing the ram but that did nothing. There was also a few times where the dell logo popped up and loaded but then these crazy colored lines appeard on the screen and that was it. Please help!
Is dit een goede vraag?
1 Opmerking
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Hi,
The colored line is a bad connection between mainboard to screen ( broken or ripped cable, dirt, ...)
Or a failing GPU.
in case of juice spill , you need to clean the main board immediately with isopropyl alcohol. is it long ago the spill?
try to clean it anyway... but do it propperly , use enough of isopropyl ( you can buy this at a drugstore...)
clean every connection.
This is a good time to clean the fan en colling pads as well. check transistors an capicitators for leak also check the chips on the mainboard. clean the ram would help but i think it will be to late , try with other ram after cleaning.
Most of the time the keyboard is dead to.. replace this as well.
Kind regards,
kevin
Was dit antwoord nuttig?
2 opmerkingen:
Do you mean clean the motherboard? This all happened last night.
door
indeed i mean to open the laptop and clean the components at the motherboard.
if you spill some liquid it will go to the motherboard...
door
Voeg je antwoord toe
Tariq G zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 9,571
