Ga door naar hoofdinhoud
Repair and disassembly guides for Kenmore Microwaves.
Repeats 1234 error code on display screen
We had a severe storm which resulted in a power outage for about 24 hours. When the power went on, our microwave started to run though numbers on the display screen. 1 2 3 4. It runs through each number about 4 times until it stops on 1.
Update (07/24/2016)
It's a Kenmore model number 721.80032700.
Is dit een goede vraag?
4 opmerkingen
What microwave is it. Make and model number please
door
Thank you, I will try it.
door
That worked! Thank you for your help.
door
Glad I could help ;-)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sometimes shutting off the circuit breaker that the microwave oven is connected to for 30 seconds will clear the fault, error or function code; however, there are some cases when further service may be required.
http://products.geappliances.com/applian...
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jackie Dobransky zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 321
