Ga door naar hoofdinhoud
Also known as the m300, the Clip is a simple MP3 player by SanDisk released in 2007.
How to replace dead battery in Sansa Clip mp3 player?
1. How do I open the case without damaging it?
2. What is the right soldering tool to unsolder old battery?
3. What is the right temperature for soldering tool? (To minimize or eliminate harming electronics)
4. Identify what the battery leads are attached to.
5. What should be unsoldered first,then next?
6. What is correct solder to resolder new battery?
7. Show replacement battery for ipod that will work in Sansa Clip.
Is dit een goede vraag?
Score 6
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
Hi Susan ;)
From one Sansa Clip enthusiast to another, I hope this helps!
How to replace a Sansa Clip internal battery.
1. To open the case you'll need a plastic prying tool.
http://www.meritline.com/new-diy-repair-...
http://www.youtube.com/watch?v=6LRyDOxbd...
2. You'll need a pencil-style soldering iron.
3. 25-watt for general circuit board work, I use one that switches from 15 to 30-watt. Radio Shack sells several models for under $20.
NOTE: When soldering electronics with irons greater than 15 Watts, minimize extended contact with the board (more than 5 seconds at a time) as it can cause damage. Also, after soldering a point, let the solder cool for 3-5 seconds before wiggling any wires and etc. as it's still molten and they'll shift out of place if it hasn't hardened.
4 & 5. An example of the tools and the battery which is a replacement for an ipod shuffle.
http://anythingbutipod.com/images/forum/...
The old battery has an attached small board which is connected to the player via 3 wires. This board has to be reused, so rather than removing the wires, you have to remove the board from the battery. This also means you have to take care not to damage the board.
To do this, desolder the points on either end of the small board where two silver ribbons from the end of the battery cell are connected, don't worry about the condition of these since they're part of the battery and will be discarded. Also, notice on the battery surface it shows + on the left and - on the right, FYI.
After that, you will have to do the same on the new battery, since the Shuffle circuit is not compatible. Same procedure, two points on either end of the small board attached to the battery cell, however take care to keep the silver ribbons as intact as possible, the board can be damaged since it will be discarded. The poles are the same, and similarly labelled with a + on the left, and a - on the right.
Note: Many times batteries come with a plastic label stuck to the outside of it, this can be easily peeled off to reveal the attached board and + - markings on the battery casing, just be careful not to damage connections from battery to board.
Last, you might have guessed, solder the new cell to the board which the old battery was removed from. Once soldered, you can clean it up a bit with some rubbing alcohol and Q-Tips if it looks gooey. Cover the board connections and battery end with one or two wraps of electrical tape. Don't overdo it so it's not too thick. Lay the battery in it's new home! Adding a piece of 2-sided tape or such to hold it in place is optional but probably not needed.
Reassemble, taking care to seat the power and volume buttons into place BEFORE you forget and have to pry it apart again.
6. Standard electronics silver-bearing solder, 62/36/2, I would use .022 or .015 diameter wire, you won't need much though. Might pick up some copper desoldering wick also (all sold at Radio Shack) for removing excess. Can be a lifesaver.
7. Replacement for iPod Shuffle battery 616-0212 (the original iPod part number) is what you'll need to know, since there are lots of after market battery manufacturers to choose from. The original Clip battery is 3.7V 300mAh, so make sure to get the shuffle battery that is 300mAh since they also sell a 250mAh. They both would work, the 250 won't provide as much playtime per charge though.
That's it! New battery should have around half a charge, which you can use, or charge as you usually would, and go!
Good Luck!!
Cory ;)
Was dit antwoord nuttig?
Score 6
5 opmerkingen:
Thanks Cory! This is great, utube video, plus photos, plus all my questions answered. I'm lovin' it. P.S. I'm glad I was patient and waited for someone into Sansa Clips to find my question.
-susan
door
Will this work with a sansa clip PLUS model? Or just the original Clip?
door
Links to anythingbutipod.com are now dead, but the images can still be found on archive.org.
door
Private utube video?
door
too bad this very detailed list does not contain many details, such as how to open the device and what batter to replace it with.
door
The Only thing i could find:
Repair Sansa Clip
Hope it helps you
Score 2
2 opmerkingen:
Thanks Peter, I'm glad to see good photos of how to begin opening up a Sansa Clip. When added to Cory's Answer, I see better how to proceed. -susan
door
URL no longer works. 03/07/2018
door
Also--make sure the battery is dead. I'm glad I watched this first:
https://www.youtube.com/watch?v=K2Qgtkkv...
Also, this Sansa page has similar instruction (i.e., things to do before declaring your battery dead):
http://kb.sandisk.com/app/answers/detail...
I love my Sansa Clip! I've had it for ages now and it's still going strong. Thanks for posting this question.
Score 1
JUST DID THIS WITH A 1400mAh battery!!! 25 hour life!
I can't ensure this won't cause a fire, but if you are buff enough at electronics, to test it for 1-2 weeks charging and it doesnt explode, then you're fine. I tested the charge and it can't go to high levels above 4.20 volts.
1/get a 1400 mAh of same size as sansa clip, i got nb-4l canon battery.
2/take out the old battery and wires, the charger doesnt need the thermal sensor!! cool. it's superfluous
3/solder the new battery to the + - only, and make the lease about 5-10cm, passing pass the leads through a hole you make above the clip hinge, so you can glue the new battery on the hinge plastic.
4/close the sansa up, tape the battery terminals up, score the 2 surfaces to glue, glue the battery to the sansa clip
Here are pictures of the mod:
SANSA CLIP MOD
1 Opmerking:
i have a sansa clip +8. battery like is down to nothing. i have had it for four years now. i need a new battery where can i get what i need.? dhopper.1974@yahoo
door
Hi! Replacing the battery in your Sansa Clip sounds like a great project, and I’m happy to help with your questions! To open the case without damage, use a plastic prying tool, like a spudger, to gently separate the seams, starting at a corner. For unsoldering, a 25-watt soldering iron works well for circuit board tasks; aim for a temperature around 300°C to avoid harming electronics, and keep contact brief (under 5 seconds). The battery leads are typically connected to a small board, which you’ll reuse, so unsolder the battery from that board first, not the wires. Use lead-free rosin-core solder for resoldering to ensure a clean connection. For a replacement, an iPod Shuffle battery (3.7V, ~100mAh) can work, but double-check the dimensions and connector match your Sansa Clip model. Have you confirmed your Sansa Clip’s exact model number yet? That could help ensure the right battery fit!
Voeg je antwoord toe
susan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 37
Afgelopen 30 dagen: 196
Altijd: 91,810
