Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
iTunes 1671 error and lines on screen
Hi after display replacement everything went good, but after few days screen went red. I did dfu but it shows me 1671 error and white lines on screen. I tried to replace everything(battery, display, charging port). PLEASE HELP ME. I tried to restore on 2 PC.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
https://www.youtube.com/watch?v=NEsP_fwi...
Was dit antwoord nuttig?
5 opmerkingen:
this should fix your problem
door
This way it shows me 2009 error.... any ideas ? Maybe try to restore on mac ?
door
yes try to restore on your mac
door
in my experience all apple devises very picky about what cables it will restore with. Error 9 is almost always related to the cable, NOT the dock connector/flex cable. Use the official Apple cable if you still have it, or borrow one from a friend.
If that doesn't work, it might also have something to do with the IPSW you are trying to restore with. Try using a different IPSW or using redsn0w to boot pwned dfu mode and restore like that. It could be this because of the error can be related to the ramdisk kernel rejecting the ASR because it is not signed properly, thus breaking the connection with the device and causing the error
door
How error 1671 iTunes can be fixed?
In order to fix this problem you have to follow the steps mentioned below:
The antivirus has to be updated and run the full system scan to make the device free of virus.
In order to make the iTunes compatible the current iOS version or the iDevice that you are using, you have to update it to the latest version.
You should connect your iPhone, iPad or iPod Touch with high-speed USB port.
Your computer should have the latest version of operating system.
In this way you can fix this error.
door
Voeg je antwoord toe
robinfrolik zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 143
