Ga door naar hoofdinhoud
Instructies, begrijpbaar door een machine, die computerprocessoren aansturen om foto's van katten op het internet te tonen.
SQL server after RAID problems
We had a SQL server die due to some RAID problems. We sent the machine out to a data recovery company and they are able to recover the .MDF and .LDF files from the drives. Will I be able to use those files to restore the databases to a new machine?
What do I need to watch out for? Thanks!
Is dit een goede vraag?
Score 1
1 Opmerking
You've been very kind in your efforts to help. Thanks for that. Solved!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Have u tried out the old way of creating empty database with same name.
Stop sql server
Paste database at the same location ...
And restart the server ....
Does it helping u out .....
If that doesn't help, then the only thing I can advise is to try to restore database using SQL Server Recovery Toolbox. All the details about this program can be found at the link. http://www.oemailrecovery.com/sql_repair...
Was dit antwoord nuttig?
Score 1
1 Opmerking:
May be this article will give you more information.
http://www.techrepublic.com/forums/quest...
door
Voeg je antwoord toe
DanielNetrval zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 699
