Coffee grounds in cup while brewing
Grounds coming out of K cup while brewing
Is dit een goede vraag?
I periodically insert a safety pin into the top needle....then I choose and run the "hot water" function....you should notice grounds in your cup. Repeat the safety pin procedure until the water is void of grounds. Others may use a straightened paper clip. Be careful.
BTW: I often do this during the brewing process....the brewing stops when you lift the lid.
Was dit antwoord nuttig?
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 101
