iPhone 6 Plus says "searching" or "no service at the top.
I'm working on this phone and it appears that the only thing wrong with it is that it says "searching" or "no service" at the top. I have tried two working SIM cards and both do the same. At one point it had signal and worked, but as soon as I put the customers sim back in the phone it went back to saying "searching"
What I've done:
Reset network settings
Reset all settings
Checked for network update
Put in recovery mode and restored
Installed an antenna that I know works
Any ideas on what else it could be?
Is dit een goede vraag?
Check date and time. set it manually. then restart it
door jamsheer kp
Setting it manually would take ages as it would be on the year 1969 or similar to that. Plugging it into iTunes should automatically fix up the time. You can also enable set date and time automatically in settings and connect to a Wi-Fi network to sync the date/time or you can use cellular data from a sim card with data enabled and working.
Does the phone still display an imei number in settings > general > about phone?
door Ben
Date and time are correct, but just to make sure I synced it with iTunes. Yes the imei is still displayed.
door justin epley
Ok so here's where I'm at. Everything looks normal on the board. I don't have a microscope to check it out closer though. I put the SIM card in, turned it on, went to settings, and then phone. It asked if I wanted to update network settings so I clicked ok. When it did this it went from searching to no service, but never connected to a network. I reset network settings and when the phone came back on it said searching again so I removed the sim and put it back in. It went right to no service. What do you think?
door justin epley
