Ga door naar hoofdinhoud
The 2008-2012 Ford Escape features a revised front and rear fascia and restyled LED tail lamps.
50 Vragen Bekijk alle
Moderate windshield wiper speeds not working.
I have a 2010 Ford Escape XLT V6 4WD, and some of the windshield wiper speeds do not work. Only the moderate speeds. I have slow full speed, but none of the others work. I've been able to get by, with treating the glass with Rain X solution but I really want to have all my speeds. I think it's the switch, because it does work when you use the spray fluid button.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
You can try changing the windshield wiper/washer switch. It will involve taking apart the steering column trim. If you don't think that is in your capability, find a good local garage and they can help you out. Good luck!
Was dit antwoord nuttig?
Voeg je antwoord toe
Sean Ryan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 280
