Ga door naar hoofdinhoud
6th generation Android smartphone designed by Google and manufactured by LG. Model LG-H790. Released October 2015.
20 Vragen Bekijk alle
Looking for Nexus 5x Schematics
I have a Nexus 5x that won't charge because of water damage. I opened it up and it looks like there might be damage on the quick charge circuit but I don't know what to test for. I need some schematics to see what parts are supposed to be capacitors and what parts are filters or resistors. I have tested the battery connectors on the motherboard and I don't have any voltage there. Also the place where the quick charge chip is heats up when it's plugged in. Does any one know where I can get schematics for a Nexus 5x? I can't seem to find them anywhere on the internet.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
forum.gsmhosting.com is where I have the most success finding phone schematics in searchable pdf format, but it’s pretty hit or miss and lots of old, dead links. I can’t find the 5X on there at the moment, but I’ve found many other useful ones in the past.
Was dit antwoord nuttig?
After more research I have found that most smartphone manufactures do not release schematics for there devices. So it looks like I am out of luck for finding schematics unless they are released. I will try to troubleshoot with my multi meter more and hopefully be able to find the broken connection or component.
1 Opmerking:
Hey I know I'm a bit late on this one, but I am now going through the same issue, and I need the schematics too. Did you eventually get it? If you did, could you send it to me please?
door
Voeg je antwoord toe
alexander zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 3,292
