Ga door naar hoofdinhoud
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Black LCD then no light
I dropped my Ipad mini last morning and at first it turned black, and after a few shake it turned back, while using it my ipad turned black with light so i decided to restart it by pressing the start and home button at the same time... and after a few try i noticed my ipad mini won't work... there is no light on it, I tried to charge it but the battery logo won't come out. What should I do?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Most likely the connector came loose when you dropped it, or you damaged the LCD in the fall. You'll have to take it in for repair at a local shop, or get the parts here on ifixit and follow the guide and do it yourself.
Make sure you get a digitizer too if you do it yourself. Even if the glass isn't broken, you'll likely destroy it in the removal process.
Was dit antwoord nuttig?
Voeg je antwoord toe
Jec Tan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 51
