screen replacement gone wrong
Iphone 6 plus cracked screen, screen plus digitizer replaced but accidentally miss installed the cables. screen turns black. Is there anything that I can do? other than buying another screen?
Is dit een goede vraag?
This is a belated answer so hopefully it can be of use to folks who search for and find this question.
When inserting a connector in the wrong place, it is possible that the connector was damaged. You have to closely inspect the connector, preferably with magnification, to see if any pins were damaged or if the plastic casing of the connector was mangled up.
Any damage to the (screen) connectors will require that you replace the screen. If the damage is on the logic board connectors, then those can be replaced via micro-soldering.
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 142
2 opmerkingen
Can you please expand upon what you mean when you say a cable was not installed properly? It is very different if there was damaged to the cable on the screen vs. a connector on the board.
Thanks
door Owen Cunneely
Hi Owen, Thanks for your inquiry. I inserted the cable from the digitizer. on a different slot, it fits though but it was a wrong slot.
door jeffrey Ramos
