Ga door naar hoofdinhoud
6th generation Android smartphone designed by Google and manufactured by LG. Model LG-H790. Released October 2015.
89 Vragen Bekijk alle
Bricked Phone help me bring it back Alive
please guys anyone help me !
what can i do to my phone i was facing some problems with it and my friend tried and failed by loading a wrong boot on it so the phone is worthless right now it's not starting or giving any respond when i connect it to my laptop and i didn't get the chance to use it i only used it for a month .
Please any suggestions or ideas would be appreciated
Is dit een goede vraag?
Score 1
2 opmerkingen:
i'm using a converter because in my country we don't have the proper cable
door
Hi, how is everyone doing? I also bricked my device. It's also not able to go into fastboot. It's a moto G X1032, and android 5.1 was installed on it before flashing. I tried using file from this link https://forum.xda-developers.com/moto-g/... to revive it but it failed. please help, thanks.
door
Voeg een opmerking toe
2 Antwoorden
You likely just need to reflash the factory images. Just boot into fastboot by holding volume down and power, and flash the factory image from here: https://developers.google.com/android/ne...
If your phone shows QHSUSB_BULK in device manager, it is much more complicated. It seems that there is no unbrick method for the 5X currently if you are stuck in that mode.
Was dit antwoord nuttig?
10 opmerkingen:
i pressed volume down and the power button put it didn't do anything
door
Plug the phone into the computer, what do you see in device manager?
door
it says unknown USB Device
door
Can we get a screenshot? Also what cable are you using.
door
door
5 commentaren meer tonen
So, what was the final chapter? Could you turn it on? I have this issue: sending sparse 'system' (524289 KB)... FAILED (too many links)
1 Opmerking:
try a different usb port
door
Voeg je antwoord toe
Mostafa Heikal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 5,409
