Ga door naar hoofdinhoud
I need bios rescue password 2012-01-01
hi i need BIOS RESCUE PASSWORD for my asus m80ta
i test ABLDABLA and not work for me plz helpppp
Is dit een goede vraag?
Score 9
12 opmerkingen
hi i need BIOS RESCUE PASSWORD 2012/01/04
=== Updaten (19-10-17) ===
door
door
Didn't solve the problem
door
Same problem here, ABL… Password for 2012-01-01 not working.
Any other solution?
Just want to come in bios so we can install new Windows, set boot to USB..
door
No didn't fix it and I forgot the master password on Asus laptop
door
7 commentaren meer tonen
Voeg een opmerking toe
5 Antwoorden
Het nuttigste antwoord
ABLDABLA (NOTE: must be all Caps)
Was dit antwoord nuttig?
Score 5
2 opmerkingen:
if AZERTY keyboard : it's QBLDQBLQ
door
Parfait fonctionne sur x552mj
door
Hi All
If you can find the older topics, you can find the solution, anyway reshare again
Try this method, turn on the computer and access BIOS
Please visit this link below.
https://pastebin.com/raw/L3c3rySj
Subtract current year and get the password
e.g.
2019 - 10 = 2009
2018 - 10 = 2008
2017 - 10 = 2007
.. etc
For example:
  • At the password prompt, press alt+r
  • Take note of the date displayed. For me it was 2017-05-11
  • Use Ctrl+F to search the paste bin for your month and date. I used "-05-11"
  • Use the codes you find until one of them works. Mine was the same code as 2007-05-11 from the paste bin.
  • It looks like the codes might repeat every 10 years. So I would suggest starting with the month and date combination from 10 years prior to whatever date is displayed after you press alt+r.
Score 3
2007-01-01 ABLDABLA igot for 2012/01/01
Score 1
2 opmerkingen:
2012-01-07 please
door
Code worked for Asus X551M 01/01/2012, thanks
door
Disconnect the cmos battery from your computer then re plug it, this will reset your bios.
2 opmerkingen:
Some of us don't have battery inside ;)
door
hi same problem with 2012/01/01,
anyone can help?
thanks
door
para los que aun no desbloquean aca esta el unlock x fecha https://www.biosbug.com
goathack vzla
1 Opmerking:
No funcionoa, al menos en mi transformer T200TA no sirve el pasword generado con el dia 2012/01/08
door
Voeg je antwoord toe
saman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 17
Altijd: 7,930
