Ga door naar hoofdinhoud
The D-Link DIR 600 (also known as the "Wireless N 150 Home Router") is a wireless router sold by D-Link. It supports the 802.11n Wi-Fi standard, which means it can achieve transfer speeds up to 150 Mbit/s.
Internet is not working through wifi
When the wan cable connected to laptop it works . internet works fine but when it connect to the router internet is not working.
Is dit een goede vraag?
Score 1
1 Opmerking:
I have the same problem and I have tried the below steps but still I am facing the same problem.
door
Voeg een opmerking toe
1 Antwoord
1. Reset the router (reset will set your router to factory default setting, so you will have to configure your wife again)
3. Connect WAN cable (Internet line/connection from the ISP) to the yellow port
4. Connect your laptop to the WiFi and see if internet is working.
Was dit antwoord nuttig?
Voeg je antwoord toe
Chetan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 2,527
