Ga door naar hoofdinhoud
Repair guides and disassembly information for Huawei's Android-based smartphones.
20 Vragen Bekijk alle
Internal storage damaged and is now unavailable
Everytime I turn my phone on it always says "internal storage damaged and is now unavailable. Please choose one if the following"
A) restore factory settings
- but it won't let me choose this option.
B) restart phone
- I've already done it but it has gone back to the same thing.
Is dit een goede vraag?
Score 28
4 opmerkingen
what is the solution this problem huawie internal storage is damage
door
If you can do a factory reset then attempt it this may repair the problem but in most cases the memory in the phone is corrupted and not repairable . If you can preform a factory reset you will lose all your data but you will have a usable phone again .
door
wipe data wil solve your problem but you will lose your data tested by me
door
@emanco80 he does not need the data tested by you, so I think it's fine if he looses that! :)) learn how to write first, idiot! and no, it will not solve the problem! how can a data wipe repair broken memory clusters? just go away man
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
probelm with EMMC IC no way to repair only change IC
Was dit antwoord nuttig?
Score 8
Voeg je antwoord toe
kaycee ngawhika zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 15,970
