Ga door naar hoofdinhoud
Repair and disassembly guides for desktops manufactured by Acer.
WiFi completely gone, no networks
I was disconnecting/reconnecting wifi for a reason I can't remember. Next time it shows no networks at all and I can not connect I restart assuming it would resolve the issue but it didn't, i tried restoring it to a previous point but that also did nothing
wifi card is fine in device manager
any ideas that don't involve replacing the antenna lol? this is all in one machine and a night mare to repair
thanks all
Is dit een goede vraag?
Score 2
1 Opmerking
Does it "see" any wifi networks and can you see the wifi status symbol in the corner doing anything? What model is your PC, what OS are you running, and is the wifi card aftermarket?
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Hello David F im my opinion it could the the drivers of the wifi are corrupted this is not a 100% sure that could be the problem but since you say that is a all in one Desktop I really dont trust AIO PC.
You could download this free Legal program that will install 100% updated new drivers (driver park solution)
https://drp.su/index.htm
This could fix your problem with the wifi driver
HOPE THIS SOLVE YOUR PROBLEM :D
Was dit antwoord nuttig?
Score 1
1 Opmerking:
i will try thanks
door
Open Network and Sharing center
On the Left click "Change Adapter Settings"
Right click on one of the devices/options on the right hand side and make sure that they are enabled!!
Just put a bit of vinegar on it pet !
Voeg je antwoord toe
David F zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 657
