Ga door naar hoofdinhoud
This is a phablet called Fonepad Note 6 released in January 10th 2014, not to be confused with the Asus Padfone.
6 Vragen Bekijk alle
Why wont it charge anymore?
i cant get my asus fonepad 6 to charge anymore. i used to have to wrap the charger around it but that ended up breaking the wires on the charger and no matter what brand of new charger i get it wont charge. its less than 2 years old, i love this [home and want to continue to use it. HELP HELP PLEASE!!!!!!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If you've had to wrap the charger around it to keep it in a certain position in order to charge it, you might need a new port. Unless you pull the cord straight out each time, you risk loosening the charging port from the board.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
katphowell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 152
