Ga door naar hoofdinhoud
Guides and repair information for Shark vacuums.
Why is there no suction from brush on button
Shark navigator swivel plus vacuum
Vacuum only year old. Have washed all filters and bag is clean. The vent in the. Front of vacuum blows out tons of air and no air pulling up from bottom
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Most Frequent Causes for Vacuum cleaner won't pick up, no suction
Cause 1
Air Filter
The air filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner’s manual for cleaning instructions.
Cause 2
Exhaust Filter
The exhaust filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner’s manual for cleaning instructions.
Cause 3
Vacuum Hose
Remove the hose from the vacuum cleaner, stretch out the hose so that it is straight, shine a bright flashlight into one end of the hose, and look through the opposite end of the hose. If the flashlight beam is not visible from the other end of the vacuum hose, this indicates that the vacuum hose is clogged or obstructed.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
sihadley611 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 142
