Ga door naar hoofdinhoud
Released December 2008.
6 Vragen Bekijk alle
My phone turns on at midnight.
Hello,
my phone has a peculiar problem (not very serious but a little annoying): it turns on at midnight (even during a full moon). Indeed, if my phone is off, it shows the LG logo during 10 seconds and if it's still on, my phone display turns on, like if I press a button.
The guilty is not an alarm since no one is enabled (or one at 6.30 AM).
Is that problem had happened/is happening to you?
If yes, how did you solve it.
Thanks for your response.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
You might have the on/off timer enabled in the settings. I'm not farmiliar with this phone, but you could probably fix it by messing around in the settings a little bit.
Was dit antwoord nuttig?
Score 2
I did not found the solution (there are not timer in the options). So I reinstalled the firmware in my phone and it doesn't turn on at 12.00 anymore (nor at 5:15 PM, by the way).
Thanks Chris for your answer anyway.
Voeg je antwoord toe
Bob zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 2,043
