Ga door naar hoofdinhoud
Repair guides and support for 20" Intel iMacs by Apple.
892 Vragen Bekijk alle
Install Snow Leopard on 20" iMac without optical drive
I upgraded from Snow Leopard to Mavericks to Yosemite on 20" iMac.
The device is functioning unbearably slow.
I have the snow leopard DVD that came with the computer. But the optical drive is not working on it anymore.
The optical drive is not available as the product now is obsolete.
I attempted to install from recovery partition, it did not work as there seems no recovery options when I boot to that window using Ctrl+R.
Living in an area where I cannot arrange for another apple computer or laptop so I could install OS via another apple drive.
The only option left is to copy the contents of DVD to a USB and install from it.
However, not sure how I can achieve that. Need help!.
Is dit een goede vraag?
1 Opmerking:
Exactly which 20" iMac do you have?
door
Voeg een opmerking toe
2 Antwoorden
Use an external CD drive from walmart or use disk utlity to make a bootable Usb
Was dit antwoord nuttig?
Try Command-Option-R instead of the regular Command-R, this should launch Internet Recovery and you'll be able to reinstall Snow Leopard over the internet without the use of a DVD or USB drive.
Voeg je antwoord toe
fkqrf zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 54
