Ga door naar hoofdinhoud
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
271 Vragen Bekijk alle
My note 5 got wet
my note 5 got wet not much but now the back button is not working what should i do to get it back working
Is dit een goede vraag?
Score 5
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
If its just the back button then you can replace it and all will be right
Samsung Galaxy Note5 LCD screen & USB board & Home button Replacement
There is a small cuircut board that can be replaced
They can be purchased on amazon or ebay. Sorry there not available here
Was dit antwoord nuttig?
Score 1
1 Opmerking:
hi i droped my samsung galaxy note5 in the water and i dont no what to do?
door
My charging port got wet and my phone won't charge correctly, I don't know what to do.
1 Opmerking:
Firstly you can try to make the charging port dry,such as blotting paper,hair drier with very little wind,etc.
If it is still not work,I think you need buy a new charging port flex cable and replace it.
door
Well instead of paying for it to get fixed you can easy just let it completely dry and backup all of your photos,videos,and contacts. And master reset it. That's what I did to mine and I dropped it in a fish tank
1 Opmerking:
I cleaned a clients note 4 thoroughly. Still didn't work as some component chips are burnt.
door
Hi I have a stylo 5 and I just got a stylo 5 and I dropped it in water. After i put it in rice it would only turn on and then say it has no power. My phone won't charge when I plugged it in or show the light that there is a charge. I put it back in the rice to try to dry it out again but I was just wondering what else I could do to try to get it to start charging
Voeg je antwoord toe
vlutchman23 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 6,327
