Ga door naar hoofdinhoud
De MacBook Pro is Apple's laptoplijn voor recreatief en professioneel gebruik. Deze reeks bevat onder andere de MacBook Pro 13, 15, 16 en 17-inch modellen met daarin weer verschillende modellen die gekenmerkt worden door hun respectievelijke Unibody, Retina-scherm en Touch Bar-ontwerpen.
20007 Vragen Bekijk alle
Vraag afgerond
HDMI connection
Is there any way to add a HDMI outlet to my Mac Book pro? Currently I have to hook up an audio cable and a video cable when connecting to my TV. It would be nice to have just one connection and wouldn't that also give a higher quality picture?
Is dit een goede vraag?
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
All you need is this
Was dit antwoord nuttig?
Score 1
No. You would have to drill a hole in your case for the connection and then find room in your laptop for the hardware. The only thing that I can suggest is to use the mini display port and a converter to get the closest quality picture to HD.
The mini display port adapter is all well and good, but only if you have a unibody MacBook. If you have an original MBP, you can get a simple DVI to HDMI adapter. However, you won't be able to send audio out through that.
Here's a DVI to HDMI cable that should work:
http://cgi.ebay.com/NEW-DVI-HDMI-DIGITAL...
You can go to try [Audio Book Converter|this].
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 2,765
