Ga door naar hoofdinhoud
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
218 Vragen Bekijk alle
Why is my phone not charging?
so my phone was charging lastnight but sometime in the esarly morning it stopped charging and went completly dead. i tried to plug it back in whan i got up and there is a red light that keeps flashing what does that mean?
Is dit een goede vraag?
Score 1
2 opmerkingen
if i reboot it will i lose anything like apps or pics or music
door
I have been doing that for months now. NOW it is Constantly losing power. I think I need a battery!
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Try charging from recovery mode...
With the device turned off and plugged in, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
If it starts to charge:
Press the Volume down button to highlight reboot.
Press the Power button to select
If the battery is absolutely, completely dead, sometimes it won't even have enough power to instigate boot or a charge cycle. Recovery will *usually* boot as it requires less power consumption, and from there it may start to charge.
If this isn't the solution, it could be that the battery has reached its end of life, which would mean you would need to replace it, and from what I've read may now not be possible at all due to the manufacturer sealing the device after people had attempted to remove the battery having not realised it wasn't designed to be removed.
Personally though, I've never seen a device that the battery cannot be removed from with some tinkering. Unless they did something different with this one!
Was dit antwoord nuttig?
Score 2
i KNOW exactly what to to.....FOLLOW MY INSTRUCTIONS . plugthe phone in and wrap the cord around the phone (up wards) and """leave it be for a couple hours"""
1 Opmerking:
How many hours
door
This phone is terrible why don't you send a replacement
Voeg je antwoord toe
Heather Willmer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 5,343
