Ga door naar hoofdinhoud
Reparatiehandleidingen voor veel Nikon spiegelreflexcamera's and compactcamera's.
1462 Vragen Bekijk alle
What causes the camera get an error code of LENS ERROR?
When my Nikon Coolpix S4300 camera is powered on it appears like everything is normal. After about 5 seconds the code of LENS ERROR comes on the screen. Nothing can be done except to power off the camera. If I can't fix the camera I will have to buy my wife a new one!!
Is dit een goede vraag?
2 opmerkingen
@dlojjo71 Does the lens extend from the camera when the camera is turned on?
door
Yes the lens extends and the display shows whatever the camera is pointed at.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
sounds like a misaligned or damaged lens mechanism. When they are dropped or jarred the gears get knocked around or the mechanism breaks. When the camera trys to adjust the lens it sees resistance and cannot then throws that error
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you. Not the answer I was looking for. LOL
door
Voeg je antwoord toe
David Olson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 108
