Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
Can I Fix Itunes Error 53 After Water Damage Repair
Hello,
Basically what happened is I tried to restore an iphone 5 to factory settings via hard reset with itunes, (it is not icloud locked I just wanted to update & restore the device) and now I am getting error 59, or 53, I cant remember, about 75% through the restore process.
I found the phone was water damaged, so I removed the shields & cleaned the whole logic board, and I'm still getting the error.
Does this mean
A) The parts such as charger port/aux jack/speaker are broken and wont allow the phone to restore?
B) The phone is fried
...it was working before i did the restore
If there is a way to revert back to its setting before the restore that would potentially help the issue. If thats possible?
Any and all help is appreciated.
Is dit een goede vraag?
2 opmerkingen
its error 50*
door
I have put the logic bored in a new chassis, and it had no effect. Does this mean the logic board is dead?:/ How can I revive it...?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi Zachary,
Did you notice any chips damaged or missing? Before and after clean? If so, it would be wise to replace them, as this may be the possible cause to your errors.
You could also try the logic board in a known working housing with working parts, so you know it's not the parts causing errors. :-)
Was dit antwoord nuttig?
Score 1
1 Opmerking:
yes i was going to try that & i guess i will now... is there anyway to restore the phone to its original non-reset settings?
door
Voeg je antwoord toe
ZsTech zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 131
