Ga door naar hoofdinhoud
Announced - 2014, November The Samsung Galaxy Core Prime (G360, G361) is powered by 1.3GHz quad-core processor, and it comes with 1GB of RAM. The phone packs 8GB of internal storage that can be expanded up to 64GB via a microSD card.
67 Vragen Bekijk alle
How do I fix Horizontal lines on my screen?
My phone is showing thin black horizontal lines on the screen, so it looks a bit like the screen of 1980s television. It covers the entire phone, and it happened a few days after the screen protector on the top right corner of the phone cracked. Otherwise, the phone still looks fine. It wasn't that bad at first, the screen just looked like the display was only showing every other line, but when i accidentally put pressure on the top right corner of the phone (where the screen protector cracked), it got worse and started looking like how I explained it above.
Is dit een goede vraag?
Score 32
17 opmerkingen
Everything on the screen is also tinted a bright white-ish color.
door
I also have this problem. Happened one day after my phone filled up. The screen has also been cracked a little bit for a really long time.
door
Ok so like i have a 1890 screen on my phone and it has red line on and and it changes colors and it been craked for a while now
door
Idk my screen is all white and purple and green lines, and i can only see the backroud from the tiny space thats on the bottom
door
Please take it of
door
12 commentaren meer tonen
Voeg een opmerking toe
7 Antwoorden
Gekozen oplossing
Usually it's the LCD. After a drop it can happen and the LCD will have to be replaced.
Was dit antwoord nuttig?
Score 9
7 opmerkingen:
Great
now I have to go somewhere other than school to fix it
door
actually if you gentley massage with your finger applying slightly more pressure you can make them go away they are called dead or black pixls to revive their color gently massage in smal circles in the deginated area
door
i tried massaging it, did not work. Where could I go to fix this thing?
door
how much does an LCD cost? and will I lose my data when I get it fixed?
door
I see the entire grid beneath the screen of my mobile, a Galaxy 6 or 7. The keyboard is faintly visible beneath photos and the upper half is discolored beneath the screen. My son suggested that the screen has been "burned" from som improper usage. Can a screen be replaced or is the problem with the grid itself?
door
Reset the Wallpaper. Go to Settings. Click Display. Click Wallpapers. Click on Home Wallpapers. If you have your owm from your gallery, click on Gallery look for the picture you eant for your phone display and click save. This is how I fixed mine.
Cheers! Lisa.
Score 5
7 opmerkingen:
It didn't work
door
My nexus 5x has horizontal lines and is frozen, how can i fix that? Sometimes It will turn off other times its just stuck. I can't open anything but look at the screen.
door
My Lg fortune has horizontel lines my phone screen freezes like i can still touch it and go to other apps and stuff but what ever i was last on it is still there in the back ground also some times they start going crazy and flickering .
door
Hey thanks, changing the display to one in gallery really helped. Horizontal lines still exists, but able to still use the phone. Thanks a ton!
regards
Prathibha
door
My nokia 6.1+ fell and the screen broke and there are some horizontal and vertical lines in the borders of my display. What is this.. how to fix it
door
Hello ,just did the software upgrade that was availed on my Samsung galaxy A20 and after the installation my screen got grey vertical lines and was flickering. I hadn't dropped my phone or anything. This happened all of a sudden . How do I fix it.
Score 1
2 opmerkingen:
It's normal error of Samsung mobile, just drop the trash phone.
door
I have the same problem, mine is a new phone (Samsung A12). As soon as it charges up to 100%, the vertical lines appear. They disappear as the battery drains. What do I do?
door
Just happened to me last night, 3/4 of screen was whitish with verical lines going through, phone hept getting really hot. I tried everything except a factory reset and nothing. Finally I turned my phone off and charged to 100%. Working fine! Had a similar issue with my speaker, screen or speaker wasn't getting the right voltage. Hey give it a shot it's free..I was 5 minutes from buying a $150 replacement
screen problem new screen needed
4 opmerkingen:
if not the screen then a new phone needed
door
Why does the vertical lines keep increasing??
door
How much does it cost to replace Galaxy A6 LCD
door
My screen dead after about two months of that line.
door
Well there is a solution you have to adjust your screen through a app this will solve your problem. If the problem is because of any damage to screen then it can't be fixed.
1 Opmerking:
https://howtofixgadgets.com/how-to-fix-h... this will help you in downloading the app and to configure it.
door
go to phone then go to keyboard and press star#0star# then do all the colours in order and it should help with the lines
Voeg je antwoord toe
Charlotte MacLaury zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 94
Afgelopen 30 dagen: 402
Altijd: 313,613
