Ga door naar hoofdinhoud
This LG Tribute smartphone is identified by model number LS660. The device was released in October of 2014 and runs on the Android operating system.
20 Vragen Bekijk alle
Microphone only works in speaker phone mode
When I make calls or try to change my voicemail greeting, the microphone on my LG Tribute 2 does not pick up any voice input unless I'm using the speakerphone. I haven't had any problems using voice input for Google searches or Google Maps and since I can still use the speaker mode, I don't think it's a problem with the outside of the microphone needing to be cleaned (there's no dust or lint).
Any ideas? I've only had the phone for a month and haven't dropped/damaged it . . . yet.
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
3 Antwoorden
The mic down by your charge port is dead. There are two, unless I'm confusing myself again. The one that operates while using the speakerphone mode is up top near the earpiece. Unfortunately, I think everything is on one board in these phones, so this is not a part that can just be swapped out. I would go back to your service provider and explain what's going on. That there is no physical damage makes it probable that this is a manufacturer's defect.
Was dit antwoord nuttig?
1 Opmerking:
Yes l am agree i can change the mic but problem not solved.
door
I faced same problem.. I did clean mic.. I did reset factory setting and erased all data no use.. Beside blocking some applications may effect.. Finally I installed an app from store called (microphone guard) and its work 100%.. Just give a try
https://play.google.com/store/apps/detai...
3 opmerkingen:
I don't see how an app that mutes the mic should get a non-working mic to work.
door
ya vi el mismo comentario en otra pagina, al parecer eres el que diseñó ese programa y solo estas haciendo spam
door
I have the exact same problem. And I just bought this phone 13 days ago, and informed Boost Mobile of the problem 4 days ago.
They told me that they only exchange within 7 days.
I informed them they are doing this to a Veteran who is laid off due to the effects of Corona Virus on my restaurant. After pleading from store manager to as far up as I could go, I was offered a "open box" samsung A10e for 50.00. I looked up that phone and the phone is NORMALLY priced at 50.00 even by the competition.
So they sell me a bad phone for 200 and do nothing, and think they are doing me a favor by selling me another phone at no discount?
door
Could be a firmware or software issue. The problem with mine is that the voice output is very muffled and there is nothing blocking both mics so hopefully they can update this to add a fix or improvement.
3 opmerkingen:
"POSTED: 06/09/2016 OPTIONS
It's work, you can give a try
door
I think is the settings. No one can hear me or its muffled bad. It began after i got my Google account signed in. I've had it happen w 3 phones now. So it's a setting of some sort. But I'm wreaking my brain trying to grudge it out. I can't figure it out. Maybe it's our Google settings. There's no setting it seems for the mic that is separate that I can find.
door
Voeg je antwoord toe
Becky zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 19,476
