Ga door naar hoofdinhoud
Repair information for the Samsung Galaxy Tab line of Android tablets.
381 Vragen Bekijk alle
lcd show weird colors
Hi there everyone,
''So i repair for living mostly i find by myself what the problem is but with this one i got no idea what i could be.
so i got an client with a Samsung tab Model; GT-N8010 he come over with this tablet showing strange colors (like the colors are negative) on the lcd.
no problem i replace the lcd , everything worked perfect colors are perfect.
after 2-3 weeks client comes over again with the same issue, ofcourse hes little bit mad because he payed the repair.
thing i hope you can do answer for me:
''-can it be from dropping the tablet on ground?
-could it be lcd cable?
-is it an hardware/software problem?
-did someone experience this ever before?
thing i tried:
'''-factory reset
-soft reset
-try to put negative colors on to see ( that even worse)
sorry for my langue (im dutch)
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Clean LCD cable with isopropyl alcohol. At least 90% or better with battery unplugged. Make sure you definitely tape the LCD ribbon cable / connector down to reduce chances of it moving around.
Hardware problem. Most of the time it is the LCD cable. You probably didn't need to replace the LCD if you didn't try cleaning / replugging it firstly.
1. Can it be from dropping the tablet on ground?
Yes that is very possible.
2. Could it be LCD cable?
Yes, another possibility.
- Is it an hardware/software problem?
Hardware issue.
- Did someone experience this ever before?
Yes. Have had a few clients come in with this issue. I solved it by replugging / cleaning the LCD ribbon cable and making sure there is a sufficient amount of tape so that the cable / connector can't move around.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
thanks for the reply, gone order new lcd cable , already tried to unplug and with 99% isoprop so i guess last chance is lcd cable otherwise hardware or client droped tab...
door
This is a problem with the LCD screen. Here is one: http://www.ebay.com/itm/for-Samsung-Gala...
1 Opmerking:
i don't think so, i replaced the lcd and the same problem just returned after 3 weeks.
door
Voeg je antwoord toe
Brian ifikske zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 619
