Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Deze instantcamera van Fujifilm heeft nu een dunnere en lichtere behuizing dan eerdere revisies. De Mini 8 helpt de fotograaf door de aanbevolen diafragma-instelling aan te geven. Hij beschikt ook over een High-Key-flitsmodus waarmee de fotograaf zachte portretfoto's kan maken voor een verbluffend resultaat.
My Instax won't work
My instax switches on, all the red lights around the lens shines at once and when I click the button to take a picture, nothing happens.
It's definitely not the batteries.
Please let me know how and where I can fix this problem
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
5 Antwoorden
Filteren op:
Gekozen oplossing
According to the camera's user manual, the batteries should be replaced with the camera switched on, which appears anti-intuitive because with most cameras exactly the opposite is recommended.
Quoting from the troubleshooting section of the manual:
Replace the batteries. only when the power is turned on. If you replace the batteries while the power is turned off (when the lens is retracted), the lamps on the brightness dial blink after turning on the power even with new batteries
Try the following: with the camera switched on, remove the batteries, then reinsert them. If the problem persists, the camera might indeed be defective and it is recommended to turn the camera off and remove the batteries immediately, then have it checked by a repairperson.
Note that you must use prime quality batteries in this camera. Fresh alkaline batteries from a reputable manufacturer are recommended. Be wary of cheap batteries bearing prestigious brand names, these may be counterfeits and will not perform well.
Was dit antwoord nuttig?
Score 3
6 opmerkingen:
Thank you for your response, but I started the camera as explained on the trouble shooting. Step by step.
I had new batteries inserted, I even tried Duracell AA.
Do you know where I can repair this camera? I am based in Cape Town
door Deel
I don't have the faintest idea as I've never been in Cape Town :)
However, your best bet would be to ask around locally. If you know any photographers, ask them where they take their gear for maintenance and repair.
door Deel
Hey I'm facing the same issue please help
door Deel
Hi I have the same issue with our camera. All lights are on and it won't go off even if I change the batteries and the film
door Deel
Ever resolved ?
door Deel
1 commentaar meer tonen
Daughter's camera has the same issues. Went thru 3 different batteries. Doesn't
Score 1
Did you check shopping malls and Camera stores ? Check online and call local camera stores. One another way is buying from ebay.
Hi - Same problem here after less than 4 shots.
If it's less than a year old, send it in for warranty. You will need the receipt (just printed it from, amazon), and they will direct here: FUJIFILM Repair Form (fujifilmusa.com). Send that with the camera to the address on the repair form.
FUJIFILM Camera/Binocular Repair
1100 King Georges Post Rd
Edison, NJ 08837
For any questions, you can contact them at 800-800-3854.
I found there is a trick to change the batteries with the camera switched on. At least with my unit. What worked for me was taking the batteries out and putting them back on WHILE pushing the ON button. Push the button all the way down and keep it pressed while you take out the batteries and put them back in. Should be good qualuty new batteries.
Voeg je antwoord toe
Shihaam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 53
Altijd: 47,254
