Ga door naar hoofdinhoud
Announced in October 2013, The Nikon D5300 is an upper-entry-level DSLR with a 24Mp DX-size sensor.
Camera files destination problem
Any time I take a pic with my camera and then insert the Sdcard to the Pc . , it creates a new folder for the stack of pics that I taked . How can I fix it?
Is dit een goede vraag?
2 opmerkingen
What software are you using to view the contents of the card?
door
On pc I use Windows10 . I don't know the camera software.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Your problem has nothing to do with the camera. The camera saves your images on the SD card in folders which are named 100NIKON, 101NIKON and so forth. Image files are given a sequential number from 0000 to 9999, and only when the file number rolls around from 9999 to 0000 a new folder is created on the card.
When using a windows PC to read the card, this is the folder/file structure you should see on the card.
However, when you copy the images to the Pictures folder on your computer, Windows tries to be helpful and creates so-called virtual folders by date - which can be rather annoying if you don't want this. This behavior can be defeated: in the folder window there's a dropdown button labelled Arrange by:, set this to Folder and the virtual folders that classify your pictures by date will disappear.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Nikon D5300 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 663
