My printer is not working neither the scanner
How can I remove the scanner part and make it use as a seperatw scanner. As I have another printer so I only need a scanner. Help me out.
Is dit een goede vraag?
First just use it as a scanner and do not print to it then. Most Printer/scanner combinations do not separate. If you just want a Flatbed scanner then you will have to get one. Otherwise you have your answer.
Was dit antwoord nuttig?
Printer tells me "scanner Failure" unable to scan, copy or send fax.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 197
