Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1505 Vragen Bekijk alle
No USB Connection after I broke little SMD element near connector #4!
I can neither charge the iPhone nor connect it to iTunes. Nothing happens when the phone is connected to a USB/charging cable. If the iPhone is off, connecting a cable turn it on.
It seems I broke a little SMD element near connector4 of the logic board when I disconnected this connector with a screwdriver!!!
Does anybody know what type of SMD element that is and where I can buy it? It is so little that I lost it on my table and never find that part again!
See picture:
Update
I am having this problem, but I just checked my board and that SMD looks perfectly intact. What else could be? The connector 4 is firmly attached as well...
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 1
Commentaar:
If you still have the mentioned SMD coil and your iPhone starts up when connected with usb charger it's another problem. Start you own question!
The coil filters the USB data lines. Maybe your line is broken on another point?
door
Een opmerking toevoegen
Koop geen nieuw model.
Bespaar $10 op $50 met coupon
SKIPANDSAVE10
Bespaar nu
Take $10 off $50 with
SKIPANDSAVE10
Bespaar nu
1 Antwoord
Gekozen oplossing
I found an answer myself:
This element is coil!
Connect like this:
http://forum.gsmhosting.com/vbb/f631/iph...
Was dit antwoord nuttig?
Score 2
Commentaar:
It was the "NOISE FILTER COM MODE 90 OHM SMD" -> Digikey part number: P14216CT-ND. http://forum.gsmhosting.com/vbb/f631/iph... - Data Sheet here: http://industrial.panasonic.com/www-data... (Common mode Noise Filters, Noise reduction of high-speed data lines such as USB,
LVDS, and HDMI lines)
door
Voeg je antwoord toe
James Bond zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 5
Altijd: 13,005
